Brake warning light on - Ford Powerstroke Diesel Forum
Old 01-25-2011, 02:36 PM
Today when I turned the dial to 4x4 the brake light and alarm came on and won't turn off. I put it back in 2wd and it is still on. When the brake light is on the turn signals won't work either.I have tried pulling the e brake release several times. This happened the other day but shut off when I jiggled the brake release. I know the brakes are good and the e brake isn't on.Is there a sensor that the 4x4 switch could have set off and is it normal for the turn signals not to work when the e brake light is on.
Old 06-07-2011, 05:53 PM
Most times when the brake light is on you are low on Brake Fluid.
Old 06-25-2011, 11:57 AM
when you pull the brake release also pull up on the brake e brake pedal sometimes mine sticks and the light stays on
