P R N D 3 2 1 - Ford Powerstroke Diesel Forum
Old 01-08-2011, 03:04 PM
P R N D 3 2 1
The indicator needle has slipped/gotten out of adjustment. When in Park it points about to R. When in D it points to 3. Is there a way to adjust the indicator needle, or has something likely broken? I'm not even sure where to begin to look.
Old 01-08-2011, 03:41 PM
what year is your truck?
if you take the dash panel off under the steering column there will be a white plastic screw that has a cable going through it, put it in park and adjust that till it indicates on the P
Old 01-08-2011, 03:50 PM
my e4od has a little wheel i think. but idk about your turqshift
Old 01-09-2011, 02:45 PM
My truck is an '03 with a 6.0. The only panel under the column is the panel that covers the fuse box. I suppose this "cable" will be exiting the steering column somewhere?
Old 01-10-2011, 12:28 PM
Feedback Score: 10 reviews
i just did mine if you crawl underneath your steerring wheel youll see it. (with the cover off of course)
