65 mph + loud humming sound ?? - Ford Powerstroke Diesel Forum
Old 12-17-2010, 03:26 PM
So I get on the freeway and everytime I go over 65 I get this loud humming sound from the front of the truck, anyone got any ideas of what it could be
truck details in sig, stock wheels and tires 165k
Thanks
Old 12-31-2010, 08:01 PM
I just noticed a similar thing in my truck. Mine is when above 60 mph. but only when I let off the throttle, and just for a few seconds.
Old 02-08-2011, 09:54 AM
I wasn't going to reply because after over a month I would think you figured out the problems but Oakleyguy if you sure it's on the front I would think it would be bearing or tire.ab2625 I would think u joint or play in the rear axle,hopefully u joint.Good luck and if you figured it out already please post your findings for other that may have the same ploblems.
Old 02-08-2011, 11:23 AM
start easy, rotate tires and see if it moves. Anywhere particular in the front end? I hate chasing these gremlins on 4WD's. Most likely is driveshaft u-joint. rears usually wear faster than rears as they are under stress more often. Front axle u-joints also wear and could be your problem.
Old 02-17-2011, 12:06 PM
Send a message via AIM to wildfingas
While your driving and if you turn slightly one way or the other does it go away? Humming noise general at those speeds your saying will be a front wheel bearing. If its tires it will be there all the time even at 25 MPH you will hear the tires humming. What kind of tires are you running?
Old 02-17-2011, 07:04 PM
I get a humming sound that comes in clearly at 80mph and goes away at about 85 no idea of what it is i didnt notice it till i lifted it. I dont pay much attention to it because i rarely do 80+
Old 11-11-2011, 07:36 PM
Is the humming noise associated with any sort of Vibration?
Old 11-21-2011, 04:05 AM
USMC 0311
Also having a humming sound coming from the front end. Subscribed
Old 11-24-2011, 01:56 PM
I had a similar issue with my X, would start humming around 55-65 and go away. I had this issue for over a year. Had bad ball joints, which caused the tires to wear out of round, more humming.... Replaced ball joints, tires, problem still exists but fixed bad tire wear. Ended up being a out of balance drive shaft.
Old 05-15-2013, 07:13 AM
I get the humming at 65mph too
I have the same hum. '00 F350 7.3L automatic.
Key to figuring out this problem for me is that as soon as I drop it into neutral and the rpms go down, the hum ceases - even though the truck is still going down the road at 65 mph.
Did anyone here solve this?
