truck vibrated under hard accel... - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-15-2010, 04:01 PM Thread Starter
cconnell's Avatar
I have 88,000 miles on a 05 f-250, with a 4 inch lift an 35's with a sct tuner... I think it started about last week, about the same time I got the tuner. but it still does it with the tuner off, just not as bad. ( when i get all up in her there a vibration under the truck and wheels). Kinda like its chirping the tires... what could be wrong????? BTW it only does it under hard accel.. not when im driving normal
2005 F-250 KR with the 6.0 PowerStroke
4 inch lift, 35x12.50's
SCT X3 CUSTOM TUNED!!!
cconnell is offline
post #2 of 3 Old 12-19-2010, 05:20 PM
mines the same way all the time from 0 to 100mph but worse in over drive i cant figure it out
smithlawncare2004 is offline
post #3 of 3 Old 12-19-2010, 07:11 PM
I had a vibration problem , Thought it was a wheel bearing since it felt like it was first coming from one wheel . I found out it was my UJOINT Mount that goes into the Rear Transfer Case(Rear Driveshaft). The mount was slightly bent and my mechanic tried to BANG IT back into shape BUT I had to order a new one and once I Did that and replace the ujoints it was ALL GOOD and havent HAD ANY PROBLEMS. If I were you guys I would go to a DRIVELINE/DRIVESHAFT Expert and have them check out the whole thing. IF any piece is slightly bent (even a hair) it throws the whole drive shaft off,since its balanced,and it feels like the truck is shaking or you have bad wheel bearing(s).
AND by the way dont take it to the dealership those guys dont know DIDLY SQUAT. They turned my rotors ,replaced tha brake pads,check the wheel bearings and had the shop foreman test drive my truck and they couldnt figure out the problem.
JUst saying if you've checked the obvious out Brakes and bearings. this will be the next logical area to go to next. Especially if you have lifts and can put a strain over time on the drive shafts
2006 F350 CC LB 4X4 LARIAT
4" Turbo Back Exhaust
Sinister EGR Delete KIT
SCT SF3 TUNER Eric Tunes Coming SOON
FICM Reprogram
20K Curtis Hitch
OPTIMA Yellow Batteries
AVERAGE 5k to 6K a WEEK !!!!!
[SIGPIC][/SIGPIC]
MILEmonster is offline
