- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Axle Rap Rearend Clunk
I Have An 04 F350 Crewcab Fx4 And If I Hit My Brakes It Makes A Clunk Noise And When I Leave From A Stop It Clunks Agian I Look At It And Eveything It Tight But The Rearend Seems To Have Alot Of Movement Anyone Had Orhave This Problem And What Did You Have To Do To Fix It
| Sponsored Links |
I Think I Found A Fix
This Is What I Found
08-13-2006, 09:00 AM ******* Banned *******s Gallery Hall Join Date: Jul 2006 Posts: 273 Are you noticing the thud or clunk sometimes when you come to a stop as well? If so, sounds like it's definitely a spline grease job. Common problem with super duty trucks. You'll need to drop the rear shaft of the 2 piece driveline. Yes, make sure you mark both the shaft and somewhere on the rear differential so you can line it up correctly when you re-install it. Ford sells a teflon spline grease for this application, but unless you want to spend $37 for a pint of grease, go to your local parts store and buy some slick 50 gl1 rated grease for $6. If you're careful you can reuse the rear clamp on the rubber boot. You only need to take the rear clamp apart and slide the rear shaft off. Grease the splines and put a dab into the female portion of the front piece. Put her all back together and enjoy thud free driving. HOPE THIS WIIL HELP IM GOING TO DO IT THIS WEEKEND Last edited by saca93 : 06-27-2007 at 08:10 AM. |
thanks saca good info I'll do it too and post when done. you post too and tell us if it makes a differance |
i did it friday and its like a new truck
| Sponsored Links |
