Leaky rear pinion seal replacement - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-18-2010, 03:16 PM Thread Starter
..::ryan::..'s Avatar
Quoted: 2 Post(s)
I'm about to take my truck in to get the seal checked out because it seems to be leaking oil at a pretty high rate. I tried searching, but couldn't really find the answer, but how much do you guys think it should cost at the ford dealership to replace the seal? I already called them for a quote, but they said they would have to see it first
..::ryan::.. is offline
post #2 of 3 Old 11-18-2010, 04:37 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I'm not sure what dealers charge for replacing the seal. They are gonna need to take a look at it, because it might need a new yoke also.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 3 Old 11-18-2010, 04:42 PM
MaydayMay's Avatar
Just had mine done this summer at a truck shop and it was160.00 or 180.00 i think and they had to replace the seal and yoke. make sure they check the vent tube also
MaydayMay is offline
