06 tranny don't shift when cold - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-30-2010, 06:50 AM Thread Starter
emt59602's Avatar
my 06 with the torque shift does not want to shift right intill the tranny warms up even when the temp is 50 degrees out. I have to give it fuel let go of the pedal and it will shift hard into gear. but as soon as the gauge shows its warmed up it shift great.
emt59602 is offline
post #2 of 7 Old 09-01-2010, 01:53 PM
Chapter Director
cubalz's Avatar
When was the last time you dropped the pan and changed the fluids and filters? When you remove the pan, take a look at the internal magnet. That will tell you if there is a problem.
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
post #3 of 7 Old 09-06-2010, 07:11 PM
just to make sure you know their is a in line trans filter up front by the passenger side front wheel well, also on some models their is a third filter in line on passenger side on trans just above the pan. not to mention the screen in the pan.
24knp is offline
post #4 of 7 Old 09-06-2010, 07:14 PM
oh ya if that don't work and no metal in pan as far as you can tell it could be a solinoid package.had that happen to mine when it was pretty new.
24knp is offline
post #5 of 7 Old 02-15-2011, 04:46 PM
blue06crew's Avatar
Same issue with mine I figured it was a programming issue..this is old thread but figured maybe I could get an update!?
2006 Ford F-250 4x4 Crew Cab
SCT- DJ's Looney
AIRDOG 2
6" Rough Country 4 Link Suspension
2" billet spacer/f350 rear block
AFE air intake
5" MBRP turbo back exhaust with 6" tip
Autometer Sport Comp Guages
38.5x14.5x17 Pro Comp Xtreme ALL Terrains
17x10 Diamo Black 17 Karat Wheels
RCD EGR delete
Custom Traction Bars
Recon Smoked Mirror Lights/Cab Lights
03 Turbo
to be installed:
Whatever i buy next...
blue06crew is offline
post #6 of 7 Old 02-25-2011, 10:06 PM
Chango's Avatar
do some more searching. good luck
Awesome thread on oil / cold start issues for 6.0 ---->
Troubleshooting a no Start Condition --->
Still using Ford Coolant? ---->
Chango is offline
post #7 of 7 Old 02-26-2011, 05:28 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Check your fluid level. Also with custom tunes they are programmed to cut power up until the fluid reaches roughly 100 degrees
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
