Not your typical 4x4 problem - Ford Powerstroke Diesel Forum
Old 08-25-2010, 11:17 AM
I am having a problem with my ESOF. The lights on dash change, the transfer case changes, but the vacuum pump doesn't change the a/c works like it should. The manual hub us easy to turn and will lock in when turned to lock instead of auto.
What could be the problem? Or maybe what is the sequence that the 4x4 goes through to lock the hubs?
Thanks for the help
Old 08-25-2010, 01:10 PM
did you check the vaccuum pump tube? it can come off.....
Old 08-25-2010, 04:55 PM
Everything was hooked up like it was suppose to be as far as hoses/wires that I could see
Old 08-26-2010, 07:00 PM
Is the solenoid on the fender well switching? cause thats whats wrong with mine.
Old 08-27-2010, 10:22 AM
How can I tell if its working ?
Old 08-27-2010, 04:03 PM
its been awhile. If i remeber right its a 2 hose connector on the solenoid we took and unhooked the lines made sure it was getting vacuum to it and then hooked it up so only the vacuum supply line was on and then put it in 4x4 and i seen if it had vacuum at the other fitting mine didn't. hope that makes sence.
Old 08-30-2010, 06:23 PM
changed it and now its working but now the ac will blow out of defrost for the first 30 seconds if the truck has been turned off. Im suspecting vacuum leak but where is the best place to look and easiest way to fix.
Old 08-30-2010, 08:29 PM
Its blows out the defrost all the time when you first start it or only when its was in 4x4 when you shut it off and then restart?
Old 08-31-2010, 05:07 AM
Every time
Old 08-31-2010, 04:27 PM
If it wasn't doing it before you put the new soleniod on i would check the lines around that and makes sure they are all connected and in good shape. Other then that im not really sure
