Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 05-22-2007, 08:37 PM
sctpowersmoker sctpowersmoker is offline
Send a message via AIM to sctpowersmoker
03 6L fx4
what are the biggest tires i can fit with out a lift !?!?!
Old 05-22-2007, 10:17 PM
Powermoon Powermoon is offline
I believe you're running them. I was looking at 33/12.5s but was told I would rub so I had to settle with 285/75 R16 Toyo Open Country MTs. Even with these I still rub at full turn.
Moon
Old 05-22-2007, 10:20 PM
Raul@Stealth Automotive Raul@Stealth Automotive is online now
yup you at least need a leveling it to run any bigger... im running a 3.5" shackle leveling kit with an add a leaf in the rear and im fitting 315's
Old 06-17-2007, 11:11 AM
RescueF250 RescueF250 is offline
31x10.50's are probably your safest bet.
Old 07-03-2007, 11:26 AM
strokinandsmokin strokinandsmokin is offline
my friend is running a 285/75/16 buckshot maxxis mudder and they didnt rub on the stock rim but he bought some 16 x 10 rims and they rub pretty bad on turns
Old 07-03-2007, 11:36 AM
fyreman fyreman is offline
I ran 305/70/16's on 16x9 wheels on my '99 without any lift. The drivers inside would rub at full turn, but just a tad. So we drilled 2 holes in the fender liner and pulled it back a little with zipties. That worked. Later just for looks I added the 2" leveling shackles on the front, but I think I could've run 315/75/16's once I leveled it.
Old 07-03-2007, 12:33 PM
BigGreen06 BigGreen06 is offline
<b>Premium Member</b>
You should be able to run 33s stock height and 35s w/ a 2" leveling kit. That's what I've been told.
-BG06.
