Transmision "check gauge" light and temperature gauge problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-13-2010, 04:28 PM Thread Starter
Question Transmision "check gauge" light and temperature gauge problem
Hi folks. Hopefully someone can shed some light on my most recent problem. I've an '03 F350 Super Duty with the 6.0 liter engine. Yesterday, I was coming down a hill and applied the tow/haul button to slow me down, although I wasn't hauling anything. When I got on the flat, I forgot to turn off the tow/haul button, and the transmission "Check Gauge" light came on and the transmission temperature gauge shot to extreme hot, and the tow/haul light was blinking on and off. It wouldn't stop blinking when I pressed it. After letting the truck sit overnight, this morning all was fine when I drove it for awhile. After a number of stops around town, the same thing happened, and I noticed that the transmission shifting wasn't quite as smooth as it should be, as there was a bit of a jerk when it shifted. I checked the transmission fluid level, and it is slightly below full when hot. I'll top it up tomorrow. Any ideas why this is happening? Faulty sensor perhaps? Thanks for your suggestions.
northernpointer is offline
post #2 of 6 Old 06-14-2010, 08:17 PM
TwistedSS's Avatar
Probably the trans temperature sensor. Its about 40 bucks from the dealership and you will have to drop the pan to replace it. Remember to grab a case of Mercon SP fluid and a filter while you are there!
-2003 Excursion Limited, 6.0, 4x4, Lifted on 35" Toyo M/T's, Mickey Thompson, Magnaflow, Tuned by Quick Tricks.
-1998 Mustang GT. Typical slow 2v.
TwistedSS is offline
post #3 of 6 Old 06-14-2010, 09:49 PM Thread Starter
Thanks for the reply. Yeah, I kinda figured it was probably that after doing some research on the internet. I had the transmission oil and filter changed about 10,000 miles /15,000 km's ago, so it should still be good. I know it would be better to outright replace them again, but with such little use, would it be worth the cost? Those filters and the Mercon SP up here in Canada are pretty expensive.
Also, I've read that Ford put out a notice last year on the Torqshift trannie oil. Apparently, Ford has stated that you can now use Mercon LV as well as Mercon SP in the Torqshift trannie (is it the same as the 5R110 model??). Only trannies 6HP26, 6R60, and 6R75 are to continue with Mercon SP only. Do you or anyone else know about this? Is the LV any less expensive and more readily available than the SP???
Thanks.
post #4 of 6 Old 06-15-2010, 03:57 AM
M90Ranger's Avatar
+1 TFT Sensor
M90Ranger is offline
post #5 of 6 Old 06-15-2010, 04:40 PM Thread Starter
What's the TFT stand for? Transmission......what? Thanks.
post #6 of 6 Old 06-16-2010, 03:38 AM
M90Ranger's Avatar
Transmission Fluid Temperature
