- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Rear axle seal replacement
I was crawling around under my 2005 F250 4x4 today and noticed diff fluid leaking down both rear tires. I am picking up parts tomorrow from the dealer. The axle looks like a Dana 60 or 80 full floater. I have set up and rebuilt Dana 44's before but not a full floater. Are there any tricks or special tools I am going to need to complete this project? Any tips or advice from anyone that has done this before would be greatly appreciated. Looks like after I remove the Rotor there is 4 bolts to remove the hub and axle assembly, Seal should be in the tube and axle slides through it?
| Sponsored Links |
If the oil is running down the tires it sounds like you have a leaking wheel seal. If your truck is DRW then your axle will be a Dana 80. And if it is a SRW then your axle will be a Sterling 10.5. The procedure for changing a wheel seal is very similar on any full floating axle. You need to remove the wheel/tire, caliper and caliper anchor plate. Then you remove the axle shaft bolts and pull out the axle shaft. Once you have the axle shaft removed there is a nut that is holding the hub/rotor assembly onto the axle. The nut is a locking nut and you will need a special socket that releases the lock while you remove the nut. After that nut is removed you can remove the outer wheel bearing and pull hub/rotor assembly off of the axle. Once you have the hub removed you have to remove the seal from the back side of the hub and drive a new seal in. Ive got a ford workshop manual here that outlines the whole procedure with torque values and lots of other info. If you need anything just ask. Changing a wheel seal is not hard at all. I am a heavy duty mechanic and have changed hundreds of wheels seals on big rigs. I can have one done in approx 1 hour now including pulling the truck into the shop and waiting for parts to be delivered. Last edited by 6.0DSLPWR : 11-09-2009 at 08:57 PM. |
Here is a link to the socket that you will need. As far as I know there are quite a few companys making these sockets. KD tools is one. lisle is another, and the socket I own is made by CTA tools...I am sure there are more. Up here in Canada most auto parts stores have the socket so I am sure Napa will have it. I bought my socket from a store called Princess Auto which is the Harbour Freight of canada. So if you have a harbour freight near you the socket can probably he bought cheaper from them than napa. I am not sure of the identification numbers on the axle tags. But if your truck is a DRW(dual rear wheel) it will have a DANA 80 axle. And if your truck is a SRW(single rear wheel) it will have a sterling 10.5 axle. Not trying to bash ford but I have heard from quite a few people that they are way out too lunch on the pricing of there wheels seals for the DANA 80 axle. I just priced a wheel seal for my dads truck a few days ago at a local parts store and they wanted $20 for the sterling seal and $40 for the dana seal. I would highly suggest you price out the seals at ford and a parts store before rushing to ford for a seal. Also if the guys working at the parts stores near you are like the ones near me. They wont know the difference if you tell them your truck is a dual or single rear wheel or that you need a seal for a dana 80 or sterling 10.5. They will take your truck info(year make model) and the computer will list 2 seals for your truck...one will be a seal for a 10.5 diameter ring gear and one for a 11.25 ring gear. If your truck has a sterling axle you will need the seal for a 10.5 ring gear and if you have a dana axle you will need the seal for a 11.25 ring gear. Last edited by 6.0DSLPWR : 11-10-2009 at 06:41 PM. |
| Sponsored Links |
