Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Problems Forum > 6.0 Drivetrain problems
Old 11-05-2009, 03:11 PM
psd_va psd_va is offline
auto 4wd?
ok my since i have had my truck the hubs have never locked in auto but they will lock manually. i finally got around to trying to track it down. well i found the problem but not sure why its happening. i found that the colenoid on the passenger side under hood right by the vac pump and res. is not actuating when it should. i looked up some info on it and the 4wd control module is suppose to apply ground for the solenoid to open and aplly vac to hubs. well its not but i can apply ground and it will work. im thinking that the control module is bad possibly can i just cut the wire and run it to a switch and be able to just apply ground my self?
Old 11-10-2009, 01:24 PM
Old 11-10-2009, 01:31 PM
RcnRln RcnRln is offline
subscribed
Old 11-19-2009, 05:27 PM
any body have any thing to say about this
Old 11-19-2009, 06:30 PM
Galaxie Galaxie is offline
Does it need a new solenoid?
Old 11-19-2009, 07:07 PM
Don't think so cause I can ground the circuit and it will work
