2004 f350 ball joints - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-06-2009, 06:03 PM Thread Starter
black99stroker's Avatar
I am going to be replacing the ball joints on my truck this week and was wondering where the best/cheapest place to get them from was. Also any tricks or advice would be helpful.
Thanks
2010 f250
ext. cab long bed
4x4 6 speed
black99stroker is offline
post #2 of 4 Old 07-21-2009, 05:19 PM
ball joints
There are quite a few threads on this forum that describe the process in detail along with pictures. My only advice would be that once you get the knuckles off is to take the ball joints to a local shop to have them pressed off and the new ones in. It is alot easier and most shops only charge a nominal fee. The same would go for when you are re-installing the seal. There are instructions on this site to build your own tool but I found it still didn't work right. It was easier just to have a local guy do it for $10 that has the tool to do it.
As far as where to find the joints, there are a ton of sites that have them. Their prices fluctuate by a few dollars here and there but they are mostly all the same.
BALL JOINT | CarPartsCloseOuts.com
Shop for Ford Ball Joint at 1A Auto
Oh and when you put on the new ball joints the top one won't fit with the zirk attached. You have to leave in the screw and put the zirk in when you need to fill the unit.
bluelights76 is offline
post #3 of 4 Old 07-21-2009, 05:23 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
I bought mine at powerstrokeshop.com. I just checked they have the kit for 291 bucks. I heard their service has gone down hill though. So you might want to check other online ford part sites.
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #4 of 4 Old 07-21-2009, 05:42 PM Thread Starter
Replaced them a couple weeks ago. It wasn't too bad to do. Got most of my parts from napa and had to get a seal from the dealer. Only took a couple hours.
2010 f250
ext. cab long bed
4x4 6 speed
