2004-2005 Ford F250 Truck Super Duty 4WD Front Wheel Bearing & Hub Assembly for Model - Ford Powerstroke Diesel Forum
1A Auto Parts
post #1 of 3 Old 06-17-2013, 11:10 AM Thread Starter
1Aauto's Avatar
Quoted: 51 Post(s)
CHECK HERE FOR GREAT PRICES 2004-2005 Ford F250 Truck Super Duty 4WD Front Wheel Bearing & Hub Assembly for Models with Rear Wheel ABS & Single Rear Wheels (SRW) Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side) FRONT
4 bolt flanges
Direct replacements
Replaces dealer part numbers: F81A-2B663-EF, F81A2B663EF, F81Z-1104-ED, F81Z1104ED, F81Z-1104-EE, F81Z1104EE, YC35-2B663-EA, YC352B663EA, YC35-2B663-EB, YC352B663EB
Fits 8 Lug Wheels
Studs already installed
Built to strict quality control standards
Correct for 4WD Super Duty (SD) trucks with Rear Wheel ABS , SRW (Single Rear Wheels), course thread studs, & 13mm thick hub flange
Will NOT fit trucks with 10mm thick hub flange because it will cause the front brakes to drag
Note: For 1999 models you can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch pillar that the door closes on.
Quality
You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us.
You don't want to be delayed by a defective part. 1A Auto wheel hubs & bearings are all tested prior to shipping.
Fit Guaranteed
These hub & bearing sets will install just as your originals do. You can use your existing hardware.
Save time and money with direct fit hub bearing assemblies. No trips to the auto parts store or extra time trying to match up and press bearings.
Hub installation is a degree more difficult than changing a tire on most vehicles.
Value
Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill.
2 Year Warranty
This item is backed by a 2 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
Reference #: 515021 x2
SHOP HERE FOR AWESOME
1Aauto is offline
post #2 of 3 Old 09-16-2013, 10:20 PM
Ok dumb question here but is the only way to change wheel bearing is to change entire hub assembly?
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #3 of 3 Old 09-17-2013, 05:43 AM Thread Starter
1Aauto's Avatar
Quoted: 51 Post(s)
Yes you would need to change the entire hub assembly. It's not that bad of a job, just make sure that the center axle nut it torqued to it's proper torque setting.
Tony
1Aauto is offline
