1999-2003 Ford F250 Truck Valve Cover Gasket with Injector & Glow Plug Harness Set of - Ford Powerstroke Diesel Forum
1A Auto Parts
post #1 of 3 Old 06-12-2013, 12:46 PM Thread Starter
1ATony's Avatar
Quoted: 33 Post(s)
VISIT US HERE FOR GREAT PRICES 1999-2003 Ford F250 Truck Valve Cover Gasket with Injector & Glow Plug Harness Set of Two for V8 7.3L Diesel
FREE SHIPPING IN THE LOWER 48 STATES!!!
This valve cover gasket set is just the kit you need when you are planning to replace a leaky valve cover seals with a malfunctioning fuel injector & glow plug harness. The set contains both left & right side gaskets and integrated injector/ glow plug harnesses that are needed to replace the valve cover to the cylinder head and put an end to leaky valve covers or a malfunctioning injector harness.
This valve cover gasket repair set has the following specifications:
Made from high quality materials
Replaces one of many dealer part numbers including: F81Z-6584-AA, F81Z6584AA, 1379998
Heat resistant
Oil resistant
Direct replacement
Built to strict quality control standards
Specific to the Ford 7.3L Diesel Engines
Inner injection/ glow plug harness has female connectors
Includes everything to do the job right the first time!
This valve cover gasket set contains the following pieces:
Valve cover gaskets with dual integral fuel injector connectors - Qty (2)
Inner Injector/ glow plug harnesses with correct plugs - Qty (2)
Originals are regularly damaged during repair
Original glow plug connectors fail due to excessive heat
Correct outer connector plug with pigtail harness for splicing if needed - Qty (2)
Note: For 1998 models you can find the production date of your vehicle on either the outer edge of the driver's front door or on the latch piller that the door closes on.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
DORMAN #: 615-201 x2
SHOP HERE FOR AWESOME
1ATony is offline
post #2 of 3 Old 06-26-2013, 06:32 AM
Hi Tony!
How important are the T-shaped snap covers that protect the harness where the wires branch off to each glow plug?
I believe that they shieled the wires from premature heat degradation plus oil and dust.
Can they be procured individually?
Thanks.
2006 F-350 Lariat Fx4 CC SRW SB 6.0
All OEM upgrades, Garrett Powermax, A1 1722 studs, OEM headgaskets,
175/30 sticks, -EGR, Magnaflow -feline, Driven regulated return, PE TC,
5R110 refresh + upgrade, Edge Insight CTS, SCT-X3 + Aggresive Tuning.
Dirck is offline
post #3 of 3 Old 07-11-2013, 11:09 AM Thread Starter
1ATony's Avatar
Quoted: 33 Post(s)
Originally Posted by Dirck View Post
Hi Tony!
Thanks.
Just noticed this question. We currently do not carry these protectors. You may be able to find them at the dealer.
1ATony is offline
