1999-2007 Ford F250 Truck Super Duty Mirror Power Heated Signal & Clearance Light Te - Ford Powerstroke Diesel Forum
1A Auto Parts
post #1 of 4 Old 04-30-2013, 01:38 PM Thread Starter
1ATony's Avatar
Quoted: 36 Post(s)
CHECK HERE FOR GREAT PRICES 1999-2007 Ford F250 Truck Super Duty Mirror Power Heated Signal & Clearance Light Telescoping UPGRADE Pair
FREE SHIPPING IN THE LOWER 48 STATES!!!
These replacement mirrors are just what you need to get your vehicle in good looking form again!
Specifications:
Comes as a PAIR
Fits both LH (Driver Side) & RH (Passenger Side)
Power operation
Heated
Dual Arm
Dual Glass
Manual Extending
Smoked Turn Signal Lens with Clearance Light
Textured Caps
Retrofit 2008 and Up Style
Replaces dealer part numbers: 5C3Z-17683-EAA, 5C3Z-17D743-BAA, 5C3Z-17682-EAA, 5C3Z-17D742-BAA, 5C3Z17683EAA, 5C3Z17D743BAA, 5C3Z17682EAA, 5C3Z17D742BAA
180 Degree Swing
10 Hole, 7 Pin Plug
Direct replacements
Built to strict quality control standards
These mirrors make great replacements and have good cost savings over dealer units.
Special Note:
This mirror is designed to replace an original mirror with these exact options. If you do not have the options listed, there is a possibility that this mirror may not function properly.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
This part replaces:
OE #: 5C3Z17683EAA, 5C3Z17D743BAA
SHOP HERE FOR AWESOME
1ATony is offline
post #2 of 4 Old 05-06-2013, 08:54 PM
russtwentyfour's Avatar
Hey tony I bought a set of the above mirrors a couple weeks ago off eBay and I got a question for you. Could you tell me what wires do what? I have already wired in the lights and blinkers but am about to start the process of wiring in the mirror adjustment part. Keep in mind I am retrofitting these to an f350 that never had power mirrors. I have purchased the ford adjustment switch and all connectors from ford and have schematics on them just not sure what's what on the mirrors other than the lights. Thanks man I really appreciate any help you can give me. And by the way the mirrors are absolutely awesome!
Thanks for your order...Jeeezze..I don't have the wiring diagram, what I would do is connect everything up according to Ford's instructions; make sure that there's power to and from the switch. I'd then press the mirror button and with a test light see which wire activates.
Hope this points you in a direction. Tony
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 4 Old 01-14-2014, 10:43 AM Thread Starter
1ATony's Avatar
Quoted: 36 Post(s)
back in stock
1ATony is offline
post #4 of 4 Old 03-12-2014, 01:52 PM Thread Starter
1ATony's Avatar
Quoted: 36 Post(s)
back in stock
1ATony is offline
